Processes - Adhesive Bonding
Adhesive Bonding
Adhesive bonding is a multi-purpose joining technique used through chemical adhesives to unite surfaces without significantly changing material form. Suitable for thin-walled and dissimilar material, it allows even stress distribution and smooth aesthetics in automotive, aircraft, and electronics sectors.
Advantages: Joins dissimilar/non-metallic materials, distributes load evenly, no thermal distortion.
Disadvantages: Long cure times, surface prep sensitivity, limited high-temp applications.
Applications: Automotive body panels, aircraft skins, microelectronic assemblies, sports equipment.
Primary:
Secondary:
Adhesive bonding provides high-performance, weight-saving, and corrosion-resistant assembly if controlled surface prep and curing conditions are ensured. It is a technology increasingly in demand from next-generation product design.
