Processes - Mechanical Fastening
Bolting and riveting are mechanical joining operations commonly used in aerospace, automotive, structural, and general mechanical applications where permanent or semi-permanent connections are required. The operations are best suited for assemblies with dissimilar materials or those requiring periodic disassembly (bolting).
Advantages: Suitable for all materials, good control of tolerance, and rapid lead times.
Disadvantages: Low shape complexity, may require several machines, heavy tool wear and cost, and a likelihood of excessive scrap.
Applications: Structural frames, engine mounts, brackets, enclosures.
Bolting and riveting cycle time consists of:
Cycle times vary from seconds (automatic riveting) to minutes (hand bolting). Fastening rate is largely a function of access to the joint as well as complexity of parts.
Bolting Tools:
Riveting Tools:
Principal Tools:
Auxiliary Tools:
Fasteners are often made from steel, stainless steel, aluminum, titanium, and plastic (non-structural). Surface treatments like zinc plating or anodizing improve corrosion resistance.
Prevention of these defects is realized by using proper torque control, selecting appropriate materials, and monitoring the process.
Design Guidelines
DFMA Compliance Tips:
Most significant cost drivers of riveting and bolting are:
Reduction in joint number, fastener type, and tooling may lower the assembly cost by as much as 40% in mass production applications.
