Processes - Surface Treatment
Surface Treatment Overview
Surface treatment includes various finishing operations bestowed on the surface of a material to improve functionality, look, and longevity. Surface treatments play a vital role in industries from aerospace, automobile, and biomedical to consumer electronics, where surface integrity guarantees product lifespan and reliability. Surface treatments may be used to offer corrosion resistance, wear protection, enhanced paint adhesion, electrical conductivity, or appearance finishes based on the application requirements.
Process Categories
Surface treatments can broadly be categorized into the following types:
Plating (Electroplating, Electroless Plating): Involves chemical or electrochemical deposition of a metal film, such as nickel, chromium, or zinc, on a substrate for the purpose of providing corrosion protection and surface hardness.
Conversion Coatings (Anodizing, Phosphating, Passivation): Chemically transforms the material surface to create protective phosphate or oxide films. Anodizing is widely used on aluminum alloys to enhance corrosion and wear resistance.
Organic Coatings (Paint, Powder Coat, E-coat): Deposit a polymer-based surface for protection and appearance. They are frequently utilized as topcoats on metal surfaces and may be functional or aesthetic.
Mechanical Finishing (Polishing, Grinding, Blasting): Produces specified surface roughness, gloss, or geometry. Polishing is necessary in optical and high-precision applications.
Thermal Spray & PVD/CVD Coatings: Deploys thin film or coatings through vapor-phase or molten material processes, usually applied in high-performance applications such as turbine blades or cutting tools.
Material Compatibility
Surface treatments differ by material. For example:
These treatments are likely to need pre-treatment processes such as degreasing or abrasive blasting to create adhesion and performance.
Surface Treatment Comparison
Surface Treatment Capabilities
