Material Usage
In most manufacturing processes, some material is attributed to feed systems and defective parts, which may be recycled. Calculate the total amount of raw material required, based on such parameters as the part weight, defect rate, and parts per cycle. Other useful weight calculations are provided as well, including the shot weight, material yield per cycle, scrap weight, and the weight of the parts and waste material.
MATERIAL USAGE CALCULATOR
Input Parameters
Order Quantity
parts
Defect Rate
Part Weight
lb
Parts Per Cycle
Feed System Weight
lb
Recycle Ratio
Results
Run Quantity:
- parts
Shot Weight:
- lb
Material Yield:
Scrap Available:
- lb
Scrap Allowed:
- lb
Total Material:
- lb
Total Parts:
- lb
Scrap Waste:
- lb
