Widgets |
- Design
- Volume and Weight
- Part Gallery
- Manufacturing
- Material Usage
- Production Time
- Labor Cost
- Financing
- Clamping Force
- Cooling Time
- Thermal Diffusivity
- Milling Speed and Feed
- Milling Horsepower
- Milling Step-over Distance
- Drilling Speed and Feed
- Drilling Horsepower
- Turning Speed and Feed
- Turning Horsepower
- Turning Roughness
- Sheet Metal
- Bend Allowance
- Bending Springback
- V-Bending Force
- Wipe Bending Force
- Deep Drawing Force
After a bending operation, residual stresses will cause the sheet metal to spring back slightly. Due to this elastic recovery, it is necessary to over-bend the sheet a precise amount to acheive the desired bend radius and bend angle. The final bend radius and bend angle can be approximated from the sheet thickness, K-factor, material yield strength and modulus of elasticity, and the initial bend angle and bend radius. The final bend radius will be greater than initially formed and the final bend angle will be smaller. The springback factor, Ks, will show the ratio of the final bend angle to the initial bend angle. Learn more about Bending.
